OK thank you!! Your advice is very valuable!!
Do you believe that I could use the short pipe with no issues at all?
- I will wait for you photos I just would like to see, if possible, the stand you made for the pipe inside the tunnel.
- Regarding servos, yes this is what I also think of 8411SA, plastic gears for sure. I have excluded the DEPS system I will open two little servo slots in the stab and that's it. Specially if I use the short pipe in front the plane will balance just fine.
- Do you believe I could use MK servo horns on surfaces? I wonder whether I coulld drill them an place those nice servo horns with the ball bearings....
Best regards,
Nikos
