Hey Tommy thanks once again.
I know which MK horns you mean. Thanks I will get some of those, what pushord length did you get really for the ailerons? I think MK provide some fixed lengths.
The issue with the short pipe and OTOP is that, the pipe should be placed on the composite part of the fuse the one covered by the small belly pan. Is that surface rigid enough to hold the pipe or need some kind of re-inforcement?
Here is the photo from the manual. The pipe should be placed on the wide area right?
I think that things started to become more clear to me. Thank you very much.
Any more advice is more than welcome.
Best rgrds,
Nikos
