RE: QUestion about 2 stroke aircraft engine temps
after about 5-10 flights you want to get rid of the limiter its there so you don't burn your new engine up, and is set up for rich running, you will find you will need to lean out the OS 46 after about 10 flights not much,but more than the limiter will allow.
its a great motor and will be a runner for many years as long as you don't lean it out too much.
