RE: axe cp thread
Question for anyone who as had to tear into there axe cp a bit. I dorked mine up a little. Slow flight about three feet of the ground and turned a little to sharp and sort of rolled her into the ground. All if did was break one of of the blade grips. After I got the grips on and everything I did some run ups and noticed that the center hub was wobbling alittle more than normal. I decided to take the the main shaft out to roll it and see if it was bent. This is my problem. I can't get it out. I slid the whole top assembly (squash plate, see saw, etc) off and took out the screw that goes through the main gear and shaft. I also loosened the shaft collar. I can not get it out and I don't want to put to much pressure on it because I don't want to break anything else. Am I missing something here? Something I need to remove that I missed? Any help would be greatly appreciated. Thanks!
