RCU Forums - View Single Post - Fueling dot
Thread: Fueling dot
Old 04-21-2007 | 02:22 PM
Big_Bird's Avatar
Big_Bird
Default RE: Fueling dot
ORIGINAL: nonstoprc
Big_bird and Silversurfer,
Thanks for the info. Appreciate it. One more question on the simple method. Will the gas go to the carb through the tee (and thus flood it) while fueling? The fueling valve will shut off the flow to the carb.
Thanks again.
On a gasoline engine it will take a lot more pressure to lift the needle off of the seat in the carburetor than you will have while fueling the tank through the "T".
