RCU Forums - View Single Post - Maximum articulation...?
Old 04-21-2007 | 02:59 PM
Acs_guitars's Avatar
Acs_guitars
Default RE: Maximum articulation...?
ORIGINAL: m1marty
ORIGINAL: Acs_guitars
if you want a pretzle that does not perform well... get a clod axled, STICK style crawler
And that's why the "Stick" and "Pimp Cane" chassis are winning and placing well in so many comps.
My 2.2 class Pimp Cane (12.5 inch chassis) flexes to about 60 degrees. Haven't found the need for much more and a little thing called "float" works to your advantage.
If you read what I said, I did not say anything bad about the stick chassis at all, just that a stick will allow the articulation he is talking about.
if you want a pretzle that does not perform well... get a clod axled, STICK style crawler and you can have as much articulation as you could ever want--- possibly 180+ as long as the wiring allows [&:].
TIP: Read things and consider the context before you mock someone.
