RE: Wheeeeeeee.......... Blade CP!
My heli is in a million peices because there was a few things I needed to upgrade (like a new tail wire and fuse mod, and some new foam tape), and I wanted to get a weight on alot of the parts, so I just decided to take it down a bit further to weigh things. This is what I have so far.... any other things you can think of to measure while I have it all apart? I probably wont be taking apart the head to measure each peice, because an overall weight seems good enough to me, and also I have not measured the stock tail setup because my bro has it on his science fair project =P I will probably get that done this weekend. As soon as I get it all done, I'll have it avaiable for whoever wants to look at it. These weights should be accurate within 1g, and in most cases 0.5g. Let me know if you see any descrepencies
plasti-blades pair 35.5g
ping pong gear 19g
stock landing skids 15g
stock sym blades pair 20g
stock main motor wire lead 1g
stock 9T main motor w/out screws 49g
stock 8T tail motor w/out screws 8.5g
stock tail motor wire lead 3g
stock canopy w/decals 11.5g
stock tail rotor 4g
stock tail gear, shaft and tubing 1g
micro heli cnc dual tail motor mount 5g
micro heli vertical cf tail fin with cnc holder and screws 4g
micro heli cnc dual tail complete setup including motors w/screws, prop, gear, shaft and microheli fin 31g
5 mini automotive fuses 3g
6 mini spade connectors with plastic insulation 3g
stock CF tail boom 6g
PE foam main blades by themselves pair 11.5g
w/blade root strengthened by superglue and 2 washers for each blade pair 15g
Main motor heatsink 4g
Complete stock CPP head with flybar and paddles with 2 extra fly weights and swash 42g
Stock fly paddles 8g
2 flybar weights 2g
complete superskids assembly 44g
Commonsense RC 1250mAh 3s 8C lipo 102g
Stock 800mAh 3s 10C eflite lipo 66.5g
SSG Scott's 3s lipo battery monitor w/jst inline connectors 5.5g
3 in 1 plus receiver and antenna 28g
stock s75 servo with swash link 8.5g
Main gear and shaft with retention collar 10g
