RCU Forums - View Single Post - Maximum articulation...?
Old 04-21-2007 | 07:05 PM
m1marty
Default RE: Maximum articulation...?
ORIGINAL: Acs_guitars
ORIGINAL: m1marty
if you want a pretzle that does not perform well... get a clod axled, STICK style crawler
And that's why the "Stick" and "Pimp Cane" chassis are winning and placing well in so many comps.
My 2.2 class Pimp Cane (12.5 inch chassis) flexes to about 60 degrees. Haven't found the need for much more and a little thing called "float" works to your advantage.
If you read what I said, I did not say anything bad about the stick chassis at all, just that a stick will allow the articulation he is talking about.
if you want a pretzle that does not perform well... get a clod axled, STICK style crawler and you can have as much articulation as you could ever want--- possibly 180+ as long as the wiring allows [&:].
TIP: Read things and consider the context before you mock someone.
Maybe you didn't read what you wrote???? Unless I took what you typed "If you want a pretzle that doesn't perform well" totaly wrong, it "seemed" to me that you were talking down on them. I wasn't "mocking" you either, just pointing out that they do work (and well at that)
TIP: Read what you wrote before responding to someone when they respond to you. I'm in no way wanting to start an argument. If I took what you typed wrong, then I stand corrected and do apologize.
Have a good one.
Aaron
