RE: 3000 mah NiMH Battery Pack trickle charge question
hi,
is there a conection between mah and trickle curent seting? how do i know the trickle curent i must put on the ICE charger for a given batery pack?(i think it is imposible to find out the discharge rate you mension above without spent the whole day) is there a simple rule?
what if i dont charge the packs without the trickle curent?i dont care if i have a few mah lost.
also how do i find the corect setting for the delta peak?it has to do with voltage or mah of the pack?
thanks very much
achilles
