RCU Forums - View Single Post - Saito 65
Thread: Saito 65
Old 04-22-2007 | 01:47 PM
P-40 DRIVER's Avatar
P-40 DRIVER
Default RE: Saito 65
Keep the rev's down on that motor or you will blow it up. nothing over 10,000 static on the ground peaked. 12-8, 13-6 works well with that engine but you will need to do some experimentation to find best combo. The 65 has a low red line and a long stroke and a small carb so high rpm's do nothing, pulls real good in the low to mid 9's. Keep it a bit rich too or you will be an unhappy guy as well.
