Uneven aileron throws.
Hi,
I thought the beginner’s page might be a good place to start. I have built a scratch. Low winger and I can't get the aileron throws equal.
The ailerons are controlled by one servo in the centre of the wing and I have used torque rods (professional not home made) .I have checked all lengths and angles and they seem OK. I did have trouble with the servo arm positions but after trying several arms I have found one set that are 90 Deg to the servo! I could play around with the end throws etc but I would prefer setting the ailerons up mechanically true rather than using the electronics to iron out the problem. Is there a sequence that I should follow to sort out the problem?
Any advise gratefully received,
Richard.
