RCU Forums - View Single Post - Global Ultimate ARF
Old 02-19-2002 | 10:16 PM
magnum's Avatar
magnum
Default Global Ultimate ARF
Spock,
I did see your post. How did you mount the dual servos for the Ailerons? Did you mount them in the center where the original was or outboard.
How did you mount the dual elev servos, curious as to how you beefed the area up, and how it's holding. What brand are the HS225 servo's not familiar with them. I use mostly Futaba, but I do have a couple extra Hitec BB's I might use.
If you have some pics of the wing and servo mounting I would like to see them. I can add ply on the outside of the fuse, but not sure how to mount some on the inside, or if it's needed.
