Problem with H9 Cap Vertcal Stabilizer
I have two H9 Cap 1/4 scales. The 1st has been a dream and went together without a hitch. Well I have hit a problem in my second. The vertical stabilizer does not fit the slot in the fuselage. I compared the two planes. The fuselage slots are the same on both planes. However, the vertical stab on the second is about 5/8" too long, nose to tail. Wonder if anyone else had this problem and if so what you did? I.e., did you cut the stab or lengthen the slot in the fuselage. thanks.
