RE: Nitro models pusher Bobcat?
Looks the part can I suggest that you reverse the rear undercariage legs
If you leave where they are now you will have a lot of trouble getting the model off the ground, in fact it could leap into the air and stall if you are not careful,
you really need to have those rear wheels closer to the C/G so that It can rock a little on the rear wheels
They do fly well with no vices as long as the C/G Is correct
cheers G.
