RCU Forums - View Single Post - E-FLITE BLADE CP PRO
Old 04-23-2007 | 02:56 AM
  #1675
mrasmm
Default RE: E-FLITE BLADE CP PRO
ORIGINAL: Junktim
Can you just use silicone grease on everything? That seems like it'd be easiest.
I made it through two battery packs of hovering practice, with no major crashes. I gave myself a bigger "box" - the racquetball court down at the nearby school. That worked pretty well, since it gave me some shelter from the wind, too.
My tail has about had it, though. It never really recovered from my first major crash and blade strike. I landed pretty hard about 2/3 through my 2nd battery, and the tail is now very sketchy. It seems like it occasionally struggles to keep up with what the gyro is telling it to do - lagging first, and then going into overdrive. I think I need to upgrade that next.
My boom is also pretty splintered. It still holds the tail on, but barely. I've been avoiding this repair since I've never soldered anything before. I own a soldering kit, but have never had to use it. Now's my chance, I guess.
This might be your problem... to see if the tail is still aright, you can try to CA the boom so it becomes more rigid again. The splinters in it could be making it wag. If that is the problem, just replace the boom =)
oh yeah and silicone you can use on everything... but on some things it could get flipped off because of the high speed... the teflon would be good for those places.
