RCU Forums - View Single Post - mounting engines
Old 04-23-2007 | 06:33 AM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: mounting engines
Flyin High,
That right thrust is built in for a reason, and you shouldn't try to correct it. Rigth thrust is built into a plane to counter the tendency a plane will have to pull to the left due to the rotation of the engine. Depending on the type of cowl you have on the plane you can build/assemble the cowl so that it matches the angle of the engine so it's less noticable.
Hope this helps
Ken
