RE: GST revs but BARELY moves? HELP!
Hey JUCD VPR,
After having quickly checked all the above things, can you see movement in the following places? (Put her on a block of wood or a stand or something simmilar, when engine is running).
1/. When you rev your engine, does the flywheel turn? If not why?
2/. Does the clutch engage, & turn the pinion gears? If not why?
3/. Do your spur gears turn? Firstly, 1st gear? If not why?
4/. Does the other side of your tranny's 1st gear shaft turn when its spurs turn? If not why? (see where I'm going with this?)
5/. Does the other shaft in your center tranny also turn? (3rd speed shift assembly). If not why?
6/. Does the output of your center tranny turn? (output brake drive cups). If not why?
7/. Does the input drive cups to your diffs turn? If not why?
8/. Does the output shafts from your diffs turn? If not why?
9/. Is there a solid connection, between your axles & your wheels? therefore do your wheels turn? If not why?
I Guess what I am saying is, follow your drive line all the way through, to find where the driving force stops. Then you will know where the failure is.
Hope this helps, .46NitroAddict [>:]
