RE: mounting engines
Check the distance of the prop hub of the engine from the firewall. On planes with an angled firewall and cowl, the instuctions should tell you how far forward to mount the engine. If you move the engine forwards or backwards from that point, the end effect will be for the prop hub to move left or right of center.
