RE: Bad Super Stearman
No the positive incidence of the lower wing is correct.
You can also see this in the picture Hambone1 posted of his Stearman.
Even if it were a few degrees off, you would only have seen a rapid climb, not a looping tendancy.
It sounds like you had the C.G. way off the mark.
The plane should almost feal nose heavy with the C.G. set properly.
