RE: Uneven aileron throws.
Hi all,
I have now posted one picture of the completed plane and also a couple of shots of the servo/aileron set up. Today I took the plane out and had a fly.It is a bit slow on the rolls but other than that you would not know that the ailerons are set uneven.
The left on full rates ( and this applies to both rates) 5/8 up 3/4 down and it will be reversed on the right hand wing ie the right hand wing will be 3/4 up 5/8 down! I just don't seem to be able to cure the problem. Hope yo can locate the picys OK.
Richard.
