RE: Sonic 500 arf first flight
rmenke
You should redo the wing bolt blocks right from the start and bend the landing gear forward to the leading edge. The plane likes to tip over like a mustang, bending the gear forward takes care of this problem. I have seen two sets of wings come off on less than perfect landings. Both broke the wing bolt blocks off clean from the fuselage.
