RCU Forums - View Single Post - I'm Blowing Hot & Cold between Nicd & Nimh
Old 04-23-2007 | 02:40 PM
armody's Avatar
armody
My Feedback: (10)
Default RE: I'm Blowing Hot & Cold between Nicd & Nimh
Hi again,
My Tx battery pack is not 2,000 its 1,000 mah Ni-Cd. The charger is 50mah, I calculated it would take nearly 20 hours to charge, but I still noticed that in 20 hours, it did not show 11.1 volts, anyway, I asked the guy who I got the battery pack made, he said, you need to charge it and drain it, after couple of times or may be more it should charge better and show 11.1 volts. I asked him to get me a 200mah charger which probably have 12 volts capacity, so is it ok to get that charger if I can get?
Thanks for advices again
Mody
