ORIGINAL: Lunchboxer
Maybe you can do some research on the Feigao 380C to see if it uses Y-wind.. I know that's what the Trinity N-series use...
A lot of time, they look similar on the outside, but might be different inside...
ORIGINAL: Takedown
Yeah whats up with that.
Just did some very quick skimming and found that they also use the y-wind setup. Hmmmmm..... Well LB what would you pick if one was cheaper that the other if you didnt have the n80 already?[8D]
