RE: head bolts for OS Max .35
Brian,
The specs in the Tower page says 'Length'; not shank length.
I am not sure what 'length' means.
See this [link=http://www.microfasteners.com/catalog/products/METSCM.cfm]Microfasteners page[/link]... 20 bolts are $1.85-$2.00.
Also, the normal, standard thread pitch for a 3 mm diameter bolt is 0.5 mm.
...You wrote 0.8 mm... Are you sure?
A tech-shop that sells metric bolts is the only option to be sure you get the correct bolts.
