RCU Forums - View Single Post - add balsa to the leading edge
Old 02-23-2003 | 04:00 PM
Flypaper 2
Default add balsa to the leading edge
It would add a lot more torsional strength as it turns into a box leading edge. Try twisting the wing now, then try it after you sheet it and see the difference. It's worthwhile. Pin the wing down with a bit of washout in it before you put the last top LE sheeting on.
