RCU Forums - View Single Post - add balsa to the leading edge
Old 02-23-2003 | 04:59 PM
TerrellFlyer
Default add balsa to the leading edge
the plane doesn't need washout and if washout is built into the wing inverted flight will suffer,also when sheeting the wing if the control surface is thinner than the trailing edge[wing to aileron]you will be opening the door to high speed flutter.
