RE: SIG Fourstar 40 (4*) Build Thread
Looking good. I see that you did not bevel the leading edge of your elevator or rudder. Does this give you enough clearance to get full throws without binding?
One mistake I made, which you did not, is that I didn't check that my veritical stab was aligned with the back edge of the fuselage, and I ended up with a bigger hinge gap than I would have liked on the lower rudder hinge. Your's looks much better.
Keep those pictures coming.
