RCU Forums - View Single Post - CA hinges/replace or use
Old 04-24-2007 | 04:34 PM
ouflyer
Default RE: CA hinges/replace or use
Thanks BaracudaHockey,
Yes I did drill a hole in all of my slots. Which brings another question. I'm using monokote and noticed, that after I cut open my slots again with a hobby knife, I can barely make out the center holes I drilled. Will the CA still wick down into the slot like it should? Once I put in the new hinges (withthe slot) will I still need to wick both sides, or will that slot make the CA wick onto both sides at once? Or should I try to trim out the monokote away from the slots?
CC
