RCU Forums - View Single Post - Will it burn?
Old 04-24-2007 | 06:22 PM
Airforce7's Avatar
Airforce7
My Feedback: (31)
Default RE: Will it burn?
Sean or Marc,
What is the indicator on the JetCat GSU that tells you to turn the propane feed off using your described method? Is it when UAccel 2 shows, or the Temp or by sound??? I would think that when the turbine begins to ramp up past 24,000 RPM would be the time to switch off the propane feed.
Can you provide some details how you guys go about using this method? I like this idea of not having the extra valve and tubing in the jet. I suppose the ECU just goes through the motions whether the valve is connected or not.
Also, Do you plug the one-touch fitting on the turbine after the start sequence?
Thanks, Ken
