RCU Forums - View Single Post - Here's a Simple & FREE First Foam Build Plan! Cool Looking Plane Too...
Old 04-24-2007 | 07:28 PM
  #1108
critterhunter's Avatar
critterhunter
Default RE: Here's a Simple & FREE First Foam Build Plan! Cool Looking Plane Too...
ORIGINAL: saucerguy
Originally I was just "scratch bashing" planes out of foam before I made a foam cutter, it's messy, but you can literally build the entire plane without any fancy tools at all. I was using my jig saw to cut out the pieces and used a rough file and sandpaper to get it to the general form, then finer sandpaper to get it to it's final form. Hacksaw blades are a popular low tech choice when cutting out pieces and I use my table saw and chop saw for the booms still since they are just simple shapes.
I used Critterhunters bandsaw technique simply by mounting the bow to the side of the table, mainly for the purpose of making a foam flying saucer, but making perfect circles with it, there are some extra steps to do one of those, especially when making a circular symmetrical wing, again, remounting the bow at a few angles around the pivot point, the tool does have major advantages with saving time and to get more precise cuts not to mention as fisher said, addressing the mess factor.
Love the table cutter. I don't even bother with wood body templates to guide me anymore. One thing I need to figure out is how to keep the wire straight and the foam. The wire, if rushed, will bend and create an angled cut. I would guess I need to increase the tension of the spring or heat the wire a little hotter and move slower? That's mainly where most of my sanding comes in. Another thing I need to figure out is how to guide the foam along a straight line for a perfect straight cut. I've done it with a straight edge by holding it with my other hand. I guess a straight board or something simply clamped down on the table cutter's face to use as my guide would work.
