RCU Forums - View Single Post - Here's a Simple & FREE First Foam Build Plan! Cool Looking Plane Too...
Old 04-24-2007 | 07:49 PM
  #1109
critterhunter's Avatar
critterhunter
Default RE: Here's a Simple & FREE First Foam Build Plan! Cool Looking Plane Too...
Also have another idea I'd like you guys to kick around. I've been toying with the idea of building my first biplane. Any good bi-plane should have a round fuse, of course. Want to use the regular white foam we use for the So plane for that. So, how to do it? I'm thinking I could heat up a metal ring of some type held in a vise with a propane torch. Then take a piece of foam that has already been cut into a long rectangle that is slighly larger than the diameter of the ring and simply slide it through the ring to cut it into a round shape, or cylinder more precisely. Ideas? Thoughts? Put Downs?
