RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 04-24-2007 | 09:46 PM
  #2247
choppersrule
Default RE: Wheeeeeeee.......... Blade CP!
ORIGINAL: Wnuk
Couldn't be happier to see you posting here again! And to offically welcome you back.............., a question!
What now seperates my CP from being a Pro. I've done LiPo, Bell Hiller, 9 tooth Main Motor and main and tail heat sinks. What makes the 3 in 1 of the Pro different from the 4 in 1 of the CP. Or is the radio differnet somehow on the Pro?
Wnuk,
Without geting super technical.. The 3n1, in the Blade Pro, gives you the options for a brusless motor, ESC, Head Holding Gyro. You can't do that with the Standard Blade CP, with a 4n1 controller, unless you do some serious Hacking on the controller. Personally, I wouldn't hack a 4n1 to make it a 3n1 controller. Just my thougts on that...
And yes, the TX is different on the Pro compared to the CP... The Pro TX has twp additional knobs on top sode of the TX. One is for adjusting the pitch of the blades when in Idle-up mode (Left knob) and the other know is fo the additional Channel 5, can be used for the Head Holding gyro or retractable skids.. (Saw that on another site, it's cool.)
Hope this helps, if not, PM me.
Dave / Choppersrule
