RCU Forums - View Single Post - Walkera Dragonfly #36
Old 04-25-2007 | 04:00 AM
  #7206
Orion1024's Avatar
Orion1024
Default RE: Walkera Dragonfly #36
sunnyl,
The only thing that comes to mind is that either the throttle channel is reversed or there is a problem with the radio. When you work on your heli slide the motor back so it can't engage the main gear and turn the blades...or if you have a brushless you can swap any two wires and run it backwards. This way you can work on it on the bench without having to worry about it going berserk.
