RE: Here's a Simple & FREE First Foam Build Plan! Cool Looking Plane Too...
Well if it's .030 or so, then piano wire comes in .032, and other sizes. It has some carbon in it to harden, so the resistance is a little higher than mig wire I think -- resistance would be a good thing -- it will provide more heat with less amps. The big problem with thick wire is too low a resistance and too high an amp range.
Stainless wire is usually even a little higher in resistance than carbon steel. I have used solid stainless fishing leader (single strand) for my hot wire bow -- but I went with as thin a gauge as I could find for a thin cut, and low amp draw (I think it's .018"). Maybe leader material in heavier weight would work well for this.
One thing I forgot to point out -- this lathe will still only make a shape of rotation -- not a flattened side shape. If you think of the Gee Bee, the nose section is circular, but the tail section is flattened. Most planes are that way, more or less -- you can't do an oval section, only circular with the lathe
The only way I know of to do a true compound fuselage shape in a solid foam construction is the profile and top view cutout, then trim and round corners as required.
There are many built-up methods for complex shapes -- but not many solid carving ones.
