ORIGINAL: GJAUBIN
Would someone explain the difference between the laminate and regular XOAR props other than construction of said props? Is the laminate prop stiffer than the regular? Advantages to each?
Does anyone have an answer to the question above? I'm wondering whether or not it is worth it for the extra money. Which version are all you guys running, the standard or laminate? If everyone is running the standard and loving it, that's probably all I need to know.
Gary
