RCU Forums - View Single Post - Will CA hinges be good enough?
Old 04-25-2007 | 12:49 PM
rmenke
My Feedback: (13)
Default RE: Will CA hinges be good enough?
EXTRA:
Be sure to run a center line on each side of the hinge with color crayon. The wax keeps the center flexable. Six drops of CA is more than enough, thats 6 drops on each surface and each side. Do a simple trial on a piece of scrap, and then argue if you must. Its usually the installer that fails, not the hinge. Clean away the excess CA with a paper towel or Q-tip on each hinge as you go. Dont want excess CA in the hinge area, will crack. ENJOY
