RE: X-Treme Composite OTOP - YS 160 Pipe Setup
Hi Tommy I have another question for the Hyde mount you used.
You said you used the ARIA which means: R:Ring, I: Built in nose ring, A: Alloy beams right? Did it fit well in terms of length? Did you use the already drilled holes of the mount or you had to drill some new ones? Do you believe I could use the ARA version where the ring is installed behind the cowl nose?
To be honest I would like to use the most simple version, the A type. However this is not currently available so I have to find the best alternative.
Looking forward to your reply,
Thanks in advance,
Nikos
