RCU Forums - View Single Post - Will CA hinges be good enough?
Old 04-25-2007 | 05:28 PM
aussiesteve's Avatar
aussiesteve
Default RE: Will CA hinges be good enough?
Excelent idea on the crayon there rmenke.
I've learnt a new tip today.
I agree with you on the 6 drops per surface per side. (24 drops total per hinge). It's just that I've seen some instructions where it is written to use 6 drops and it reads as if it is 6 drops in total. That was in an ARF that had some bad publicity in these forums a while back about the poor quality of the CA hinges. I often wonder if the instructions were the cause because I had that same ARF and never had a problem.
