P38 project
Here's a shot of my G&P P38 under construction. I had to get another set of foam wings from G&P because the previous ownwer had screwed them up. I am now fairing in the ABS top nacelle covers, and the turbochargers. I also had to remove the canopy frame work because the previous owner made a mess of cutting it out from the fuse. I will add it later after the canopy is installed, probably using abs plastic.
Vince
