thanks for the info rifraff. Is this the same CG that is listed in the book
ORIGINAL: rifraff
patzane the saito is pretty light, i have 1 1/2 pounds on mine with an OS 120 with pump and it weights in at 12 LBS, so 2 pounds with a saito is about right....
and i set the CG at 95mm from the leading edge of the wing and thats with everything as far forward as possible
good luck and happy flying
