RE: CA Glue question
I use both types,CA is a handy contact adhesive apply pressure and the wood sticks together,usually when I am sheeting a wing or fusalage I use CA because of the instant stick factor after I sheeted a wing using the recomended tite bond/alphatic resin gluing method, I will go back to using thick/med CA for sheeting.
the results were less than satisfactory with the tite bond side the side.
I used CA to glue the sheeting on all the other areas and it looks great trial and error its what works for your particular building style.
