RCU Forums - View Single Post - Snap Roll Function - New Question
Old 04-26-2007 | 08:54 AM
Krysta
Default RE: Snap Roll Function - New Question
No problem, glad to help.
To make your second Rudder servo act with your Snap roll function, you will need to do a program mix, with Rudder as master, your second rudder channel as slave. Leave the switch function Null so that it is always on and set both Rate A and B to +100%. Next you will see a box to the side of the Master - Slave boxes on the left hand side of the screen. In the left most box ( directly next to where the Master box is ) you will need to touch this until it is a + sign. This is your link selection and it will link all mixes set for you Master channel ( Rudder ) to the Slave channel ( Rudder 2 ). This will allow Snap Roll to work for both Rudders for you.
Krysta
