?? chicken stick ??
How about simply using the spinner to give the prop a quick back flip causing it to backfire, reverse direction, and start. I'm curious how common that is.
No fingers in the prop disc and no chicken stick. After a bit of practice I've found it easier than using a chicken stick and/or an electric starter. The trick is to slightly over prime the engine.
