RCU Forums - View Single Post - 9 CAP and flaps using the VR(E)
Old 04-26-2007 | 09:34 AM
Krysta
Default RE: 9 CAP and flaps using the VR(E)
Hi Dave,
This is very simple to do with the 9C. Simply go into an empty Pmix, set the Master as VR-E, and the Slave as Aileron, next sent the Link ON, leave the switch Null, and set the rate at +100%.
This should get you what you want.
I hope you find this information helpful. You can also reach our Futaba support team at 217-398-8970 opt 2, or via fax at 217-398-7721.
Sincerely,
Krysta Hunt
Product Development & Support Specialist
Futaba Service Center USA
ORIGINAL: Dave G
Hi. I've got a 9 CAP and am using a 8 channel PPM Rx.
I have a project using twin aileron servos (on ch 1 and 6) and would like to have them operate as flaps using the VR(E).
I've got the ailerons mixed using the flaperon function, but when I go to set up the flaps, the VR(E) isn't a choice. How else can I do this?
