RE: Durability of 8ight
the issue with the servos is chassis flex and the servo hitting the bottom of the chassis cause of how low they sit in the tray. just add an extra shim to both servos and make sure end points are no more than 95 percent and you will be good. now about those rear outer hing pins!
