67stang, Alan and Pete thanks for your input on this plane. Just a little info on my equipment, I will be using a JR 9303 heli radio, so my flight mode switch will controll my rates. I have it set for 3 different rates and 3 different expo's I don't know what my control surfaces deflection is off hand but after reading your posts I'm sure my low rate is a little high on aileron and elevator, but that is easy enough to change. I will be running a Evolution 100 engine with a 14X6 prop. Is this over kill? I hope not, I can switch to a 14X4 prop for now but I already bought 2, 14X6 so I will use them eventually. I knew the engine was more than I needed in this plane but I wanted it somewhat over powered.
1 I need to plug or in some way not use the third line coming out of the fuel tank, whats the best way to do this? The reason I'm not using the fill line is because I'm using an Du-Bro filler valve. I was thinking the easiest way would be to simply put a small piece of fuel tubing on the line and then fold it over to kink it shut, but this is a quick fix that I don't think will work for very long, and I'm not sure of any stopper that will work with this tank.
http://www2.towerhobbies.com/cgi-bin...&I=LXD745&P=ML
2 Will JR DS821 servos be a high enough torque for this plane? The servos have 88oz/in of torque @ 6v, yes I plan on using a 5 cell pack.
http://www.horizonhobby.com/Products...ProdID=JRPS821
If the link does not work just put the number in a search engine.
Thanks in advance for any more help.
