RE: HOTSPOT
You need to cap both- trailing edge of the wing and leading edge of elevon. 1/2 inch balsa should be plenty. Just lay it out on the wing and cut them out. I capped the ends as well with 1/8 if I remember correctly. If you add the rudders, do them the same way. But you can use 3/8.
