Ignition problem evo 36
Hi,
Could anyone advise about the following problem.
Trying to start the engine, it will usually fire after a few flips but will stop within 1 second. As the engine stops, the ignition LED illuminates permanently. When the LED is on, there is no spark.
The infos on the LED in the manual are very scarce and nothing is mentioned about illuminating permanently.
Does it indicate the module has a problem?
Note we tried different 4 cells nicads w/ the same result.
Thanks for your help,
Eric
