RCU Forums - View Single Post - Ignition problem evo 36
Old 04-27-2007 | 02:06 AM
cjshaker
Default RE: Ignition problem evo 36
Eric:
If I understand you correctly, you're using too few cells, too low of a voltage for your ignition battery.
I think you said that you're using four cell nicads, ie 4.8 volts?
On my 26CC Evolution, minimum voltage is 6 volts, whereupon the electronic ignition shuts off the motor.
That's to make it safe for using a 2S Lipo for your ignition battery.
I think you want a seven cell NiCd/NiMh or a 2S Lipo for your ignition battery?
