ORIGINAL: highlander52
Glad to hear it FLYMIKE.
I'm planning on a HS-6975 on the rudder and HS-635s for everything else...all at 6V. Any comments on whether the 635s will be enough? TIA
Im using HS-645mg from FX100 all the way around. Throttle HS85mg.
I think the 635 are faster but lower tork. Should be fine depending on the way you fly.
Im going to do slow high alfa 3D and those servos will hold for me. Just make sure there metal gear!
